Replacing only 2 1/16 Guages in 1967-68
Discussion in 'Interior Board' started by 67TXStang, Aug 16, 2010.
  1. 67TXStang
    67TXStang Member
    I'd like to replace the two outside 2 1/16 guages in my 67 Mustang with something more accurate. I'd like to use the Z series guages from Autometer. I tried to mock up this setup using an old SunPro guage. It fits but does not look very good. Does anyone have pictures or a link to a website which shows how this was done with good results?
  2. stangg
    stangg Active Member
    2-1/16" seems awfully small... I beleive most folks are using 2-5/8" guages. You can either slide them in so they are proud of the dashboard, or mount them behind. Most cut the gauge bezels off mount them from behind. I mounted mine from the front and used the autometer angled bezel / sleeves to keep the gauges all on the same angle.
    [​IMG]
  3. lethal289
    lethal289 Active Member
    Agreed. I used the 2 - 5/8 Phantom gauges mounted from the front. I mounted them straght on and like it.
    [​IMG]
  4. 67TXStang
    67TXStang Member
    I like the look of the 2 5/8 guages from the front. I might end up going that way. Thanks for the picture.
