Rotted66 Build
Got the main patch welded in was harder then I thought not a lot of room for a mig gun to move around in, had to look down the top of the shock tower just to see when I welded the front in. Also cut out the rott in the fender apron and got a patch made and will tac it in tonight.
You're going to patch up those holes in the towers someone cut for access to grease fittings too, right?
For sure I wanna match the gauge of the metal for that fix and I don't have it.
:rant
With highschool hockey finally coming to a close i found some time to step in the garage
I cut out the bad sections in the front frame and crossmember and sprayed some rust inhibitor inside, i made the patches out of 14 ga sheet metal i think that should be thick enough. I will square the holes up and trim the patches and burn them in.
Cut out bad area and made the patch, couple more areas to cut out and make the patches so I can weld it all at once
