Rough idle in gear
Rex66
1966 Coupe
302 with Holley 4bbl and Edelbrock Performer RPM intake
points distributor
C4 auto transmission
As the title states, my car is idling rough when I put it in gear (Reverse, Drive, 1, 2), but idles fine in Park and Neutral. It starts up immediately every time, and it drove fine, but would struggle when stopping at a stop sign/light, or even slowing down for a sharp turn - basically any time it idled in gear.
A little History: Car ran great until the Mallory electronics started crapping out. Car would die on the road and then wouldn't start until it cooled off. I replaced the distributor (Mallory electronic w/out vacuum advance) with a points distributor from O'Reilly's. Went ahead and replaced the coil at the same time. Ran fine for a while after that.
Checked Timing and Idle:
I put a timing light on it, and I noticed that after the engine warmed up, my timing light stopped working. Did a little testing, and I was getting a light when I put the inductive pickup on the coil wire or spark plug wires other than #1. I replaced all of the plug wires (and the big coil wire) and the distributor cap. Now the timing light works on #1 until I put the car in Drive - then I get no light unless I bump up the idle high enough so that it stops stumbling. Here's something weird... with the trans in Drive (brakes applied firmly), the idle is rough until I get the curb idle adjustment screw to just the right spot, then the RPMs jump up and the car idles smoothly. Timing light then starts working (on #1). Turn the screw counter-clockwise 1/8 of a turn or less, and the RPMs drop significantly and the car starts to stumble. Turn it back clockwise 1/8 of a turn or less, and it smooths out, but the RPMs in Park/Neutral are much higher.
Checked for Vacuum Leaks: I bought a vacuum gauge and used that to set the timing. I was pulling a max of 21-22" of vacuum from the big port on the back of the carb, so I dialed it back to 20" and tightened down the distributor. I think I ended up with initial timing at around 7* BTDC. The carb's vacuum advance port has 0" of vacuum at idle, but jumps up when I rev it - that checks out. I did lots of checks for vacuum leaks - pulled all of the different lines (brake booster, transmission vacuum modulator, etc.), plugged them, and tested - problem persists. I squirted WD-40 all around the vacuum lines, base of the carb, around the intake manifold gasket, and in the carb throats. I didn't detect any vacuum leaks.
Tested Power Valve: With the car idling in Park, I turned the idle mixture screws all the way in and the car would just about die - had to back them out quickly to keep it from dying. I'm pretty sure my power valve is working. I have performed most of my tests with the idle mixture screws at 1 1/2 turns out from closed.​
After all of this, I set the idle in Drive high enough so that it stopped stumbling and took it for a test drive. Now it stumbles under medium acceleration. Not sure where to go from here. Could it be a bad coil? Points/condensor? Carb? Fuel delivery problem?
Thanks!
my first thought is a vacuumleak at the intake.
Or your advance doesn't work as it should.
my2 eurocent.
Thanks for the reply! I haven't been able to detect an air leak at the intake. Manifold vacuum is currently at 21(in-Hg) at idle. If I had a leak, I don't think I could get 21(in-Hg), right? I also tried spraying WD-40 and carb cleaner around everything and didn't detect a leak that way.
Re: the vacuum advance... I checked the carb vacuum port and it was at 0(in-Hg) during idle, but would jump up when I blipped the throttle. With the engine off, I removed the distributor cap, then unplugged the vacuum advance hose form the carb port and sucked on it. I could see the vacuum advance arm moving the base plate inside the distributor. I think it checks out too.
I decided to check the electricals last night and this morning before rebuilding the carb, and I have found something weird (at least to me)...
The voltage at coil (+) increases with RPMs: I ran a jumper wire from the battery (+) to the coil (+) and started the car. It was a little harder to start and it idled kinda rough. With the car running, I pulled the jumper wire, and it smoothed out immediately. I figure that jumper wire was putting about 14.6V to the coil (+), which is what I measure across the battery when the engine is running. Without the jumper wire, I measure anywhere from 10.5V to 12.6V at coil (+) when the engine is running. At cold idle (choke plate closed), it's around 12.6V. At warm idle, it's around 10.5V. When I rev the engine, the voltage increases.
My pink resistance wire is in place and not bypassed. Shouldn't that drop the voltage to around 9V at coil (+)? I have a min of 10.5V. And shouldn't the voltage be constant? Am I burning up my coil with this higher voltage?
10.5V is what is expected at the coil. Voltage will rise a bit with RPMs, as the alternator supplies a higher voltage to the battery than at idle.
Sounds like you have a coil/distributor system that is not working as it should at idle speeds. Bad points? Condenser? Coil? moisture in the dizzy cap?
I was just out adjusting the points - couldn't get a feeler gauge between them (at the high spot). That's not good. I set the gap to .019" because I'm not really sure what the spec is - I see anything from .017-0.21". Anyhow, it started right up and idled nicely. Shifted into Drive, and it still idled nicely at a slightly lower RPM - very happy with that - but it bogs down when stepping on the accelerator.
Edit: distributor cap is nice and dry. I suppose it wouldn't hurt to buy a new set of points and condenser.
Problem(s) solved!! :)
After setting the points gap, I was checking the timing and everything was running great, until I re-connected the vacuum advance - then it would bog under acceleration. I removed the vacuum advance, plugged the port on the carb, and took it for a test drive. It ran great. Found that my vacuum advance canister is adjustable, so once I got that set right, the car runs great with the vacuum advance connected.
FWIW, my distributor is a Cardone re-man from O'Reilly's. I turned the vacuum advance screw all the way clockwise and tested: stalled under throttle. Turned it all the way counter-clockwise: no issues. Ended up setting it back in a bit from there and all is good.
I'm not sure how this thing ever ran before with a mis-adjusted points gap and vacuum advance.
Thanks for listening and thanks for the help!
These cars are awfully forgiving for being out of tune. Glad you got it fixed (and cheaply!).
Whoa! What you describe is exactly how my '69 302 behaves. Idle is steady and smooth in P or N, but it is rough in R,D,2 & 1. I thought that was how it was supposed to perform but it sounds like I may have some sort of distributor problem too. I've been chasing a high RPM miss for about six months, but the idle roughness has been around for a long time. I always assumed it was as a result of upgrading the cam when I rebuilt it over ten years ago. My only problem is I don't have points and I'm only generating around 11 in-Hg of vacuum. My initial advance is also much farther advanced at around 12* to 14* BTDC.
I would check for vacuum leaks: brake booster and line (if so equipped), vacuum advance, PCV, transmission vacuum modulator and lines, carb base, etc. You should be pulling 18 in-HG or more. I would set the initial timing using a vacuum gauge... set the timing where you get the highest vacuum. For me, it's around 7* BTDC.
My car is still having problems. It would run great for 15 minutes or so and then just die. It would usually die when applying throttle - I'd be sitting at a light idling fine, then when I step on the gas to go, it'd die. Then it would be hard to restart, and if it did restart, it would run really rough. After sitting for a few hours, it would run fine again. I tested the fuel pump and filter - I'm getting a good pulsing stream of clean fuel from the fuel pump (with integrated filter), so I'm sure it's not a fuel delivery problem. I rebuilt the carb and added a 1" spacer, but that didn't cure the problem (though it does seem to idle just a bit smoother now). I had a small perforation in the secondary diaphragm before the rebuild. Power valve tested okay but I replaced it anyway.
The last test I performed was checking the spark from the coil and from the #1 plug. In the no-start scenario, I pulled the big coil wire from the dizzy and held it close to a header bolt while cranking the engine. I got a weak yellow/orange spark. Same when grounding the #1 park plug - yellow/orange spark. I expect to see a stronger blue spark, so I figure it's my coil, or my wiring harness. FWIW, I performed my tests solo using a remote starter trigger... that would eliminate the keyed ignition switch as a culprit (right?) because at that point, I'm sending 12v directly to the coil from the "I" post on the starter relay.
Yeah, 15-20 minutes is about the time a coil gets hot and starts to break down. They are cheap to replace, so that's what I would do first when you found a weak spark using a remote starter.
Well crap, my son and I replaced the coil yesterday and no change. The car hasn't started for a couple of weeks now, so it's not even a hot/cold issue. It wouldn't start with the old coil and it won't start with the new one. Last post, I said it must be the coil or the wiring... I omitted the distributor, which is pretty new, maybe 6 mos old. Cap and rotor look fine. Removed the points and condenser and may replace those soon, or I may go electronic.
Getting a better orange spark from the big coil wire, and a very weak orange spark from the #1 spark plug while cranking - I'm not even sure it's sparking every time it should.
Should I try running a jumper wire from 12V to coil(+), crank, and see if I get better sparks?
This afternoon, I disconnected the red/green wire from the coil(+) and the brown wire from the starter relay "I" post, eliminating the wiring harness from the ignition circuit. I ran a new wire directly from starter relay "I" to coil(+) and used a remote starter switch and checked the spark from the big coil wire while cranking... I got a nice thick orange and blue spark that I could stretch out to 3/4" or so. Much better than without the jumper wire. Looks like we get to inspect some wiring harnesses for shorts, bad grounds, etc.
Powering the coil that way eliminates the resistance wire in the stock harness providing a few more volts of power so its no wonder you got better spark.
