@67stang get your new upper arms from John at ORP, he deburs and centers them, then welds a tab so they won't loosen up. You won't regret it.
Awesome! Pretty stoked so far.
Your Mustang looks great. Yes, the image you posted is the camber cam. Caster and toe-in/out also need to be addressed once you get the new UCAs installed.
Your garage is immaculate- how do you do that?
I can't give you firsthand experience as I've never had a car that had a starting point of a good alignment.
Caltracs are sweet and will surely stop the wheel hop. Make sure you have your springs finalized before you buy though. Different brackets based on the type of spring. See my build thread for more details.Good points thank you. Yes I did the rear shock last week, and it does ride much smoother, not so jerky. Even though I don't really do burns outs, it has a terrible wheel hop (the other reason why I don't do burn outs). But it would be nice to get rid of the wheel hop. I don't have a welder, and most traction bars wants you to weld on a bracket. Any ideas.
I took a front picture of the camber adjustment, and was previously mistaken. It looks like I do have room to adjust the camber negative.
So if that's the case should I still take out one 1/8 shim? Or what I was thinking: Maybe as it sits right now adjust the camber to see if I can get a negative camber? If so do I do it with weight on wheels? And I assume I just loosen the fwd nut, the rotate the back nut/shaft?
Thoughts anyone?
Front view looking aft.
Caster is the more tricky one as there are multiple parts and adjustments involved. Caster is, in very basic terms, determined by how much the top ball joint is moved to the rear as compared to the lower joint. Unequal shimming of the UCA and the strut rod affect it, for example. If you have more shims on the rear UCA bolt you reduce caster. Playing with the shims, however also changes your camber...hence the trickiness.
Toe is the easiest. Once you have everything else set you take measurement of the distance apart of the front of the wheels as compared to the back. You're shooting for about but no more than 1.8" toe in.
I still think you need to pull those wheel spacers and see if you have clearance. If you do, Then get your camber by moving the LCA first. In pics it looks like your wheels stick out a bit farther than ideal
I know you meant 1/8"
Missed it by one key space.
Are you saying to target 1/16" toe? I don't disagree but setting it up at home with a tape measure that's pretty tight. This is why I wrote it as I did saying about but nor more than 1/8". Better to have a tad more toe in than come up short and have toe out. 1/8" toe in is not going to cause you any problems or wear.And you would still be off by 1/16"...sorry.
No just poking fun at the math...you said 1.8"', Mark said 1/8", you said you missed it by one keystroke which I assume would be .18" which is 3/16" not 2/16" or 1/8" a difference of 1/16".
My car with the Arning drop is -1 camber, +4 caster, 1/8" TI.
Look at your keyboard. Period right next to / was my reference. Math...noooooo!No just poking fun at the math...you said 1.8"', Mark said 1/8", you said you missed it by one keystroke which I assume would be .18" which is 3/16" not 2/16" or 1/8" a difference of 1/16".
Uh what? Me no understand.It's ok, he's a little dense.
Edit: A lot dense.
Those new pics show where things sit much better. That is really close to the wheel. Your tire position inside the finder lip looks better than in the first.
