68stang289
I switched from an Accel Distributor/Mallory Coil to a full on Pertronix Flamerthrower III setup. The old setup used a female/male coil wire and the new setup uses a male/male coil wire. I picked up a replacement coil wire from Taylor to match my other wires, but it came with both HEI-style and regular socket-style connectors so you can match what you need. Having never put together a spark plug/coil wire before, I wanted to make sure I had it right.
I have slid the correct boots (already test fitted on the coil and cap) over the wires so that approximately 3-4 inches is exposed past the boots. To complete the job, I need to strip the wire to the center core, fold that center core back and over the non-exposed wire, and then crimp the socket-style connector around the wire and center core correct? I can post up some pictures of what I'm talking about if that would be helpful. Thanks!
