SPC Fastrax Caster/Camber tool
Discussion in 'Tools and Tech' started by Horseplay, Mar 19, 2017.
  1. Horseplay
    Horseplay Well-Known Member
    Anyone here have/use one of these?
    http://www.spcalignment.com/component/spc/?task=part_description&pid=91000
    I have aluminum wheels so no magnetic hub device seems doable. I intend to get the "no lip" adapters to hook onto the outer edge of the rim which would give a more stable "connection". I am also going to fab up some arm extensions to give me a means to easily measure toe instead of buying their $70 pieces!
    Just looking for confirmation this is a decent tool for the job. Thanks
  2. msell66
    I use a different setup that does the same thing.
  3. Mach1Mark
    Monkeystash (Ryan) used something like that too set his alignment on his '65 FB. I cant remember the set-up he used though.
  4. stangg
    stangg Active Member
  5. Mach1Mark
    Wow !! A $100 less for the same tool. I need one to set my alignment too . . . its too far to drive to Terrys to use his.
  6. Horseplay
    Ordered from Summit last night. Be here tomorrow. I ordered the special lip attachment tips off Amazon. Saved $15 on them over anywhere else that way. Still a rip off as I'm sure I could have made something easy enough but wanted to get the alignment project done quick as soon as the tool arrived.
  7. Mach1Mark
    Did you perform an alignment yet? How did it go?
  8. Horseplay
    Not a "real" one but I did set the tool up and mounted it to my wheel as would be required and it worked very well. I bought some aluminum angle as well to fab up some extension arms to facilitate measuring toe. Just real quick playing around showed it will be very easy to use and that my "eyeball" set-up is going to be very close! I will recommend the tool if that is why you are asking.
  9. 3175375
    3175375 Well-Known Member
    IMG_0138.JPG I have the Longacre Racing Products kit. It doesn't do toe.
