"RyanG85" said:You'll want to run the "crank" wire to a relay.
The ignition switch was not intended to handle the electrical load of the solenoid. The draw of a relay coil I would surmise to be substantially less than the solenoid."65-408" said:Why? Only reason I can see is that the ignition switch is not capable of supplying adequate current to engage the mini starter solenoid? What if the ignition switch was fed with a 20A, 12 gauge wire? I am re-wiring everything, so I can do this, as upposed to other installations that are using existing wiring...
"67 evil eleanor" said:Its not the wire size that runs to the ignition switch that is the weak link, but the switch itself. Both the start and the run side can be damaged if there is a feedback.
"stangg" said:On my chebby, I put a relay in for both the starter solenoid and also for the accessory feed.... It can't hurt to take the load off an old ignition switch
