    Dismiss Notice
The things we do for our kids! aka Mach 1 woes
Discussion in 'General Mustang Discussion' started by kb3, Mar 20, 2017.
  1. tarafied1
    tarafied1 Well-Known Member
    I am also that way but sometimes I actually enjoy it too!
  2. kb3
    kb3 Well-Known Member
    Looks to me like you are only missing that one bracket. Good luck stuffing that beast into his Mustang. I would think dropping the old one out with the K member and putting the new one in from underneath will be easier than going from the top. SO MANY things in the way on the top end! About half way into the tear down I mentioned to my friend it would have been easier to drop the motor out to do this work.
  3. tarafied1
    we have discussed that. I don't have a lift but we may be able to billy rig a way to raise the car. The old motor came out the top okay but yeah, this DOHC is HUGE!
  4. kb3
    at a bare minimum you will need to remove the master cylinder, hydroboost unit and most likely some of the AC lines to go from the top. Even then it will be a squeeze. Ford puts it in from the bottom, in fact they say you can't even remove the valve covers with the engine in the car, but it was possible, just not fun. Getting the car several feet off the ground without a lift could be problematic however.
  5. tarafied1
    we were able to leave AC, PS, brakes, etc. all in tact pulling the 4.6 out but I can see looking at your pics that it will be a really tight fit. We may have to rent a fork lift and pick the car up from the side...
  6. kb3
    I left the master cylinder connected to the brake lines, just moved it aside a bit. But it would need to go to pull the motor. As it is, we fought to just get the covers off. This weekend will be the test when it all goes back together!
  7. tarafied1
    good luck, hope it all goes well!
    thanks for the pics and advice
  8. Horseplay
    Horseplay Well-Known Member
    All that size and just wee little cubes.
    Mach1Mark likes this.
  9. tarafied1
    I know, it's physically bigger than my big block but about two thirds the cubes!
  10. kb3
    Or to mention three too many cams!
    tarafied1 likes this.
  11. 3175375
    3175375 Active Member
    Good grief - what happened to simplicity?
  12. KBMWRS
    KBMWRS Think before you HATE.
  13. 3175375
    I know you are Miley, that is why I like you.
