I'm once again seriously considering selling the '66 coupe. It's been a great car, and was my daily driver for 10 years. Now it just sits under the car cover and hasn't been driven in probably 3+ months and probably once this year. I have been having fun getting my daughter's '67 ready to go back home with her in Oakland and thinking I want another project.
I probably have over $30k in the car and it really needs nothing. It has 66k on the engine wich is a 289 w/351w heads, KB pistons (flat tops with compression around 9.3:1 with the 351 heads), Harland Sharp roller rockers, Comp Cams XE262H Extreme Energy Cam. FLowTech full lenght headers, Ford Racing double roller timing set, Performer RPM intake and jetted up Edelbrock 1405 carb. It has an AOD transmission, and a 3.50 9" traction-lok. It has a Griffin aluminum radiator and SPAL fan. It has '70 disk brakes (drum rears). Front suspsension is all new with StreetOrTrack strut rods, OpenTracker roller upper arms and spring perches. 620 # front springs with KRB Gas-Ajusts all around. It also has the Vario-Centric Camber kit and 1" Aadco front sway bar.
Paint is near perfect, as it has about 1k miles since it was re-done ... does have a chip in the rear from the time when I lost the back wheel.
The car has no rust at all, and has most of the original sheet metal on it.
So ... do you think this car could fetch $14-$16k in this market? Anything less than that wouldn't be worth it, but if I could get in that price range, I think I'll let it go to finance a new project (new project may not even be a Mustang, but it probably will be).
