    Dismiss Notice
Vulcan 1968 SOHC 427 Mustang
Discussion in 'Member's Build Threads' started by GPR, Feb 9, 2013.
  1. GPR
    GPR Active Member
    Brian finished welding and grinding on the taillight panel
  2. GPR
    GPR Active Member
  3. Horseplay
    Horseplay Well-Known Member
    Thanks, Rusty! No one ever shows the backside of stuff so you a left to wonder to what extent they went on the hidden side. If at your level you don't go for full on perfect I know I can stop being so anal about it too!
  4. GPR
    GPR Active Member
    The trunk will have upholstery if not we would make it look better.
  5. GPR
    GPR Active Member
    We decided to install a roll bar and I bought a kit from S & W for a 1968 Mustang
    We wanted to do something different so we cut about 1" off the end caps and spoiler.
    As you can see in this photo the bumper needs to be narrowed
    I cut the center out of the bumper and lined up both ends with the end caps.
    I will have to add fiberglass to get a tight gap
    Bumper fits better now but still needs a lot of work to look right
    The gap was larger in the middle so I added fiberglass
    We also added fiberglass to the bottom of the bumper
    Grabber70Mach likes this.
  6. GPR
    GPR Active Member
    The end caps were bolted and bonded to the quarter panel
    I also added a little fiberglass
    Bodywork ruffed in
    We now have a nice tight gap around the rear bumper
    Epoxy primed
    Next step is to finish the bodywork on the taillight panel and rear valance
  7. B67FSTB
    Nice bodywork you did !!!
    Is that a selfmade rollcage ??
  8. janschutz
    janschutz Corn Hauler
    Like the roll cage, will there be an issues in taking the inside qtr panel off now?
    That is on my wish list.
    tarafied1 likes this.
  9. GPR
    GPR Active Member
    From an earlier post
  10. GPR
    GPR Active Member
    Quarter scoops were bolted and bonded with 3m8115 panel adhesive.
    Major bodywork finished on the rear of the body yesterday
    Today I sprayed two coats of SPI epoxy primer
  11. GPR
    GPR Active Member
    We had to add fiberglass to the side exhaust skirts to give us something to bond to the pinch weld.
    Bonded to the rockers
    Started the bodywork
    Headlight bucket was bolted, bonded and fiberglassed to the fender
    Front fender flares installed
    Bodywork getting everything to line up
    Ready for a couple coats of SPI epoxy primer
  12. Horseplay
    Very nice. Love the difference molding in the light buckets makes.
  13. Grabber70Mach
    If I only had the money you would be one of the top shops on my list to get the body and paint work done. Now all I would have to do is buy the winning lottery ticket.
  14. janschutz
    Love the flares, just added to my wish list.
  15. 68EFIvert
    68EFIvert Well-Known Member
    Beautiful work! I really like the taillight panel and spoiler modifications.
