RagTop
Old Grumpy
I've struggled with heating problems since I bought my '69 302 vert., and that's going on 19 years. I've added a shroud, a 3 tube core, an aluminum water pump (most recently), a 160* thermostat, a five bladed stock Ford fan and I've tried various combinations of coolant. On the negative side, I've had it bored .040 over, I've replaced the stock cam with a single profile .224 duration @ .050 with a .500 lift, a 4V Road Demon, a J code '68 custom curved distributor, Ford GT40P cast iron heads, custom tri-y headers and full up Motorsport roller rockers. The dizzy was custom curved and runs at 14* base and 34* all in. This car has always hated things like parades, heavy traffic and fast food drive throughs, to say nothing of long stoplights on a hot day. In the Bay Area, where summer temps are usually in the mid 80s and a really hot day is 90*+, it struggled. Here in Sacramento, with 100*+ days a common event, it gets really hot really fast. I'm presently running 50/50 water and glycol. I am considering switching back to Water Wetter and distilled water. I am about to attempt to drain my coolant and I have a question. If I open the petcock and drain off the radiator contents and then close the petcock and allow the water pump to push additional coolant into the radiator, will that account for most of the coolant in the engine? I am concerned that running the water pump dry might damage the bearings. I don't want to pull the whole damn radiator to get most of the coolant out of it. Suggestions?
