RagTop
Old Grumpy
I've heard this before, but I fail to see how the engine/radiator combination can recognize whether the thermostat is a 160* or a 195* once the thermostat is wide open. In hot ambient weather I am sure either thermostat is fully open and the duration of the water sitting in the radiator is wholly dependent on the water pump. My problem isn't with air flow cooling the water in the radiator, it's with the engine heating in high ambient temperatures or in traffic after being driven at speed or in a drive through or when stopped at a long traffic light. It would seem that the issue is between the radiator area and the amount of heat the engine can produce. My advanced timing and .040 overbore might have an influence on the latter, but I believe the basic problem is the inadequacy of the puny radiators that Ford put on V8 small block Mustangs.You're doing yourself a dis-service by having a 160* thermostat instead of a 180 or 195*. The higher temperature thermostat will keep the water in the radiator a bit longer so air flow will be able to cool it down that much longer. With a 160*, water is continuously circulating and doesn't stay long enough in the radiator to cool down.
