Discussion in 'General Mustang Discussion' started by cmayna, Oct 15, 2011.
  1. Boom
    Boom Active Member
    She looks like she handles big packages with ease.
  2. Boom
    Boom Active Member
    Grabber70Mach likes this.
  3. Boom
    Boom Active Member
    Started taking apart the dash. Plan is full disassembly, sand and paint with rust encapsulator or POR 15, then dynamat the floor boards. Begin wiring in new AAW harness.
    [​IMG]20170520_153335 by Brett, on Flickr
  4. Boom
    Boom Active Member
    Still working on the dash. I have everything removed except the shell. Been sanding down what I can reach. It's a pain but it'll be worth it.
    I got a few little parts in, here's a shot of the super nice billet pedal from Lokar:
    [​IMG]20170523_184225 by Brett, on Flickr
    I also picked up my brake pedal from the powedercoater today. Looks almost like a new factory pedal! The pedal support also has the MustangSteve roller bearings on it.
    [​IMG]20170524_160738 by Brett, on Flickr
  5. kb3
    kb3 Well-Known Member
    Just a note on the Lokar throttle pedal, once you get it adjusted the way you want make sure you loctite the crap out of the set screw. Nothing like driving along and having the pedal fall to the floor.
    Boom likes this.
  6. Boom
    Boom Active Member
    Thanks for the advice. That would be super crappy. Better then the brake pedal tho I guess.
  7. 68EFIvert
    68EFIvert Well-Known Member
    I finally have my car running well. I took it to a new tuner who figured out my oxygen sensor on my Accell Thruster DFI system was not reading accurately. The signal would get messed up in the middle of the pull and it would make the car run really rich. The car was tuned on a mustang Dyno and managed 511 rehp and 550 rwtq. I am pretty happy with those numbers. The old tune was done on a Dynojet and managed 555 rwhp and 478 rwtq. I have heard that the Mustang Dyno is as much as 10% less than a Dynojet dyno. I don't really care what it is since the car finally runs well!!!!!!
  8. Horseplay
    Horseplay Well-Known Member
    I also suggest dimpling the splined shaft with a drill to give the set screw something to nest into. It's also not a bad idea to use a slightly longer set screw when you do this. To keep going, as long as you are at the stage of your build you are...the firewall would benefit from a bit of reinforcement in the mounting area too. Not such a big deal with the Lokar throttle but certainly with something like the MDL clutch pedal set-up. It amazed me how much flex there was across the whole area under the dash.
  9. Boom
    Boom Active Member
  10. 68EFIvert
    I am running the same throttle pedal and rollerized pedal assembly on my car. It works well. The only beef I have is the throttle pedal assembly is too responsive and I have to add another spring to firm up the pedal feel. You will like it! I do agree about the set screw on the lokar pedal. Mine wants to back out and then gets a little lateral play in the bushing.
  11. msell66
    msell66 Road Worthy
    Boom likes this.
  12. Fast68back
    Fast68back Well-Known Member Staff Member Moderator
    [​IMG]
    Damn Mark, what are you pushing the pedal with {.}
  13. msell66
    msell66 Road Worthy
    You'd be surprised how much that firewall flexes at full brake pedal!
  14. Fast68back
    I know, I've had firewall issues with my hydraulic clutch MC
  15. Boom
    Boom Active Member
  16. BLAKE
    BLAKE Member
    Not done yet, but I'm about to head out and shoot some photos and drone video of the '66. Should be fun. I'll share what I can once it's processed and uploaded and whatever.
  17. msell66
    msell66 Road Worthy
    Yes
  18. Boom
    Boom Active Member
    Local junkyard had a sale, went looking for seats, ended up grabbing the parking brake from a newer Mustang. Cost me a whooping $7. Looks like it'll be fairly easy to put in. Thinking of grabbing a piece of 1"x1" steel square tube and mounting the parking brake to that on the tunnel. That way I won't have to cut any big holes in the floor, jsut 2 holes to mount and a hole for the cable to go through.
    Got the idea from Daze cars:
    http://dazecars.com/dazed/e-brake.html
    [​IMG]20170527_130417 by Brett, on Flickr
  19. BLAKE
    BLAKE Member
  20. Starfury
    Starfury Active Member
    I got pretty much nothing productive done today. Went to Radio Shack to pick up some non-insulated butt connectors to repair my half-melted engine wiring harness, discovered when I got there that they're closed...along with every other Radio Shack within 20mi.
    So I abused the tires a bit on the way home and parked it. I'll have to hit up the local electrical supply shop on Tuesday.
