Ok I am ready to buy the rocker arm set up for the FE. I have it down to 2 choices. I am going to buy either the PRW stainless or Erson set up. The Erson run around $750 and the PRW around $500. The Ersons have full roller bearings on the shafts and PRW are bushed. That seams to be the biggest difference I see. So are the Erson rockers with the bearings worth $250 more? The plans for the car is street driven with a cam that has 228 degrees duration at 0.050" lift and 0.525 lift.
