68EFIvert
I have two sending units on my car. I have one that operates two 9" fans and the second operates the other 2 fans (4 total fans). I originally had one set for 180 degrees and the other was for a higher temperature than that. The first is located in the waterneck and the other is located in the radiator next to the outlet. Anyways, one of the fans comes on later than I wanted so I plan on changing it. I thought the hotter sending unit was in the radiator so I pulled it out. To get to it I had to pull the radiator shroud loose. Once I got it out it had 185 printed on it. I then pulled the one from the water neck and it looks exaclty like the new one I purchased but the top of it is red. The new one (on at 180 and off at 170) is black. Does anyone know if the red top may mean it is a 195 degree thermostat. I will post a picture of the new and old one with my cell phone.
Thanks for the help.
