AzPete
.....Started with no brake lights and running warm at stop lights. Now, this is a local club members 64.5 Vert in pretty good condition. It has a '67 289 and C4. I don't mind helping/teaching him what to do. After fixing the brake lights, turn signals (new switch), interior lights, and glove box light, (car has been PO fitted with a '65 dash harness only) we looked under the hood. Car has 160 thermostat of unknown age so we put in a new 180. Start the car and temp climbs right past 200+. Looking things over a bit closer and Hmmmm.....fan has a good bit of wobble. Ok, need a water pump. Plan for the next Fri. We also attempt to adjust the Lokar kick down cable and found the throttle linkage not bolted to the fire wall on the drivers side. No wonder there is no passing gear. Fixed that and now it runs a LOT better. This is today (the next Fri).
Order/received pump and the owner says can we fix the leak at the back of the intake. No problem. Pulled the water pump and he wants to fix the front main that is leaking. OK. Find a bad harmonic balancer. Rubber is shot and a good grove at the seal position. Pull the timing chain cover and sure enough, the chain has a bit of slop. Might as well replace it. Balancer and timing set on order, finished the intake and left the rest for the next Fri which will be the third Fri. I have been under the hood/dash/car of this 64.5. He asked what would be the next thing that might be bad and I told him I was not going into engine rebuild as it runs strong. I am trying top let this fellow do most of the work buuuuuttttttttt sometimes it is hard. Mechanical ability is slowly improving but the ability to work a wrench is hard to teach. He is a good guy and wants to learn all he can. Oh, and the car is now at his parents house 35 miles away due to work space. It was a cool cruise up there in his Vert.
Midlife, quit laughing.......
