Wiring diagram
Dave2g
I am pretty clueless when it comes to electrical. I want to relocate my battery to my trunk. Do you guys have a specific website that has diagrams? Or is google the best bet?
https://www.google.be/search?q=67+musta ... 00&bih=775
that should help.
Relocating the battery into the trunk is not that difficult but you have to consider some things , like thickness of the positiv lead .
I would go this way : B+ from Alternator to B+ from starter to ( through firewall ) to + junction point under dash and from there to battery in the trunk.
The - pole lead should be thick enough and well mounted to the chassis / frame.
my .02 eurocent
  • I followed Mad Electrics diagram:
    http://madelectrical.com/catalog/tm-1.shtml
    And pieced it together myself. Ordered 1/0 welding cable in red for hot lead to front and black for ground. I relocated the solenoid to the trunk also so the 1/0 hot cable would only be hot during starting and put a circuit breaker on the 8 gauge going to my alt. and used a relay just higher than my alt. output (100A). Here is my thread if it helps:
    http://www.stangfix.com/http://localhos ... ic.php?t=0
    There are a few factors that make each persons wiring a little different;
    - stock starter or high torque mini starter with solenoid on top, extra wire needed from ign. to engage/disengage solenoid separately from 1/0 hot lead or you may get run on/sticking bendix;
    - stock dist. with points (2nd wire from from solenoid needed ('I' post I think), if electronic conversion or aftermarket electronic dist. installed not needed.
    - Stock solenoid used, on fender or in trunk?
    - Does constant hot 1/0 main wire concern you? Some don't mind this and wire differently. I've had a '70 totaled in a T bone and the rocker was crushed which may have pinched the 1/0 hot and grounded it > short> fire. So I ran the extra wire so it would only be hot when cranking.
    Jon
