limeyboy
Hi all,
I've had my '70 for 3 months, steep learning curve ( steering wheel on the wrong side, red flashers which are illegal big time here and petrol at $8 a gallon so can't drive anywhere
) but every time I start it I smile
Anyway it's a mach 1 no tach ( though I fitted a Dixco copy onto the hood and it plugged straight into my MSD box and works really well) California car so no rot to speak of, I've replaced all the front suspension (Hotchkis springs) and all the steering arms ( rebuilt the cyl ram, pump and control valve and yes the valve does leak 2 drops when I get back from a run)
My question is -
What warning lights should I have, the seatbelt one works and I'm tracing the brake one ( bulb works but need to check the Prove out bit) but should it have an ignition idiot light?
I have the oil pressure, water temp, charging and fuel gauges, just dont know what warning lights I should have.
California emissions petrol tank
I would like to remove all the junk in the trunk but before I try I want to know if there is a "safe way" to seal the "assumed hole" in the top of the tank, any ideas / photos would be great.
Thanks for any ideas
JC
My question is -
JC
