Mach1 Driver
Or possibly the flywheel/flexplateSo I've checked everything and to the best of my knowledge (which isn't much) everything is as it should be per the diagram.
However when I try to crank it, I now just get that screeching noise that you get when the starters not engaging. So I thought I'd just reverse everything and leave it for another day. (Famous last words) but it does the same thing.
Do you think I have screwed up the starter and if so how do I test it?
Diagram now attached.
