"Fast68back" said:Does that red car have Camaro taillights?
"Fast68back" said:Hey Jerry! I would check the E car boards, I swear there is a car or two in there running 11's. I think Jason at Classic recreations built the car IIRC. Start a build thread on your FB!
"daveSanborn" said:Agreed that Jason @ Classic Recreation... or possibly Rich @ MustangstoFear... may have more experience with this, but here's what I can tell you as I spent 2 years on the Eleanor forums and this was a much discussed topic.
I assume you'll want to run a 335+ series tire? If you're going to go big, you might as well go REALLY big! A 315 series can be installed with less headache, but they aren't as wide as you have pictured so I'll focus on 335+.
For that width you're going to need to do at least two things:
1. Fender flares. Ones that extend the OE fenderflare an inch. There's a few ways to accomplish this.
a. Bond FG flares onto the existing quarter panels.
b. Screw/bolt FG flares onto the existing quarter panels.
c. DIY modification of the quarter panels to "reform" the existing smaller flare outward to create a larger flare.
2. Your inner wheelwells will need to be relocated inward a full 1" on each side. With your interior removed, this actually looks and is kinda easy to do. Seperate the existing inner wheelwell from the car, cutout/remove 1" of your floor/transition pan and rear seat support structure and then weld a new 1" strip in between the outer and inner wheelwell. A 335 series may actually require a little bit more that 1" per side.... and this is where it get's real ugly.... anything more than 1" per side will necessitate the narrowing of the rear seat/fold-down assembly.... AND none of your original rear FG interior pieces will fit properly without some extent of modification.
Lastly, a 335+ will likely require some modification to your existing rearend/suspension.
Now, if you want to avoid the larger headaches of a 335+ tire and just go with a narrower 315, which is still pretty darn agressive looking IMO, the fender flares and the 1" inner wheelwell relocation will work with no other mods.
"mustangstofear" said:9 inch up to 9 1/2 is your max without modifying the wheelwell. Rich.
"mustangstofear" said:Front 4.75 rear 5.5 Rich.
"Coleman" said:OK!
Ordering wheels. I am gonna get the Vintage Wheel Works 45's with the flat centers:
18x8x4.75" for the front and 18x9.5x5.5 rears
Now the tires.....suggestions please!
