1966 Seats with shoulder harness
Stokes66
Ice looked around on line for some front seats with built in shoulder harnesses but no luck. Does anyone have them or put 3 point harness in?
Sent via paper airplane
I am using 3pt shoulder systems in both the 65 & 68 with stock aeats but also added headrests.
Craig did you mount Red's to the roof area like in Shag's ? I don't recall ever seeing any pics for Red, hence my question. I kinda curious because there's no quarter window on a FB, so the belt is kinda "hidden" where it hangs down. Just curious about the aesthetics in a coupe with it dangling there.
Yes, Red's upper belt pivot was mounted almost in an identical spot, via the welder.
I used late model Mustang bucket seats, out of a '99 model, and just run the belt thru the loop that is by the headrest to make the three points. All you need is the extra long, three point belts....and the seats.
