1969 Mach 1
Sluggo
I have made the decision to sell my Mustang. There are plenty of pics here on the board and most of you know how much work I've done to it.
I'll make a fixer a smoking deal on it.
List of mods
PAW 427 Stroker short block freshened up 1000 miles ago
Modified 80s Ford cast iron heads with 2.02 intake, 1.76 exhaust, screw in rocker studs, guide plates
Lunati Voodoo 61003 camshaft, matching lifters and springs
Pro-Comp Roller Rockers
Edelbrock Performer intake
Sumitt Racing 750 cfm carb
MSD Pro Billet distributor
Hooker Competition longtube headers
Flowmaster American Thunder Exhaust
GMB aluminum water pump
Trans Dapt o-ring water neck
Stewart 180 thermostat
Griffin 24 inch aluminum radiator
Ford Contour dual electric fans
Cobra oval air cleaner
Cobranda tall Cobra valve covers
Professional Products 50 oz balancer
Ford Racing 50 oz flywheel
Ram Muscle Car series clutch and pressure plate
Custom built hydraulic clutch system
Wilwood remote reservoir master, CNC slave, Longacre braided hose
T5 5 speed transmission
Hurst Fox body shift lever and classic white ball
Ford 9 inch trac-lok with 3.00 ring and pinion (1850 rpms at 75 mph)
Opentracker Racing custom built roller bearing upper control arms
Opentracker Racing custom built spherical roller bearing lower control arms
Opentracker Racing roller bearing spring perches
Opentracker Racing roller steering idler arm
Grab-A-Trak 5 leaf mid eye rear lowering springs
Grab-A-Trak front sway bar
Grab-A-Trak 620 front lowering springs
KYB shocks
Auto meter water and oil gauges
Ford racing 5 Inch programmable tach
160 amp one wire 3G alternator
Borgeson power steering conversion.
Classic Auto Air R134 under hood conversion with upgraded condenser.
Rebuilt original evaporator assembly with upgraded evaporator and heater core.
Relays added to headlights and horns.
Starter solenoid deleted and replaced with modern relay operating a mini starter from a 93 Cobra.
LED lighting on all instruments, tail lights and front markers.
Fully carpeted trunk.
Randy,
It is a very beautiful car. You should get top dollar for it, unless they find that dead rat I had placed under your drivers floor mat.
Are you going for another Stang?
"cmayna" said:
Randy,
I ate the rat. :weas
No. No more cars. I've kinda lost my mojo. I don't enjoy the scene like I used to and have some other interests to tend to.
I do in fact have a payment plan in mind.
100% down and zero payments of 0.00 with 0% interest.
"cmayna" said:
Congrats Randy. Now you can finally buy that Camaro you've always wanted.
Can't own a cumarrow. Don't have any cinder blocks to park it on.
"RustyRed" said:
I imagine you could find some at Home Depot pretty reasonably priced. :dun
Don't see to many cumarrows at Home Depot.....mostly oversized 4x4s.
yep, there were plenty of 4x4's there today. bought 5 of the pressure treated variety for a project...
"Sluggo" said:
"70 StangMan" said:
"Sluggo" said:
Do tell Randy....where is it headed for ??
Phoenix. Been there a week already. New owner spent the first night in the garage with it. It found a good home.
So the new owner's wife put him out in the proverbial dog house, eh?
If you don't want a Camaro, I'd sell you a T-top Trans Am if you ask nice...well, ask nice and bring sufficient cash anyway. :whis
