July 2015, I agreed to buy this trailer, and brought it home by the end of the month.
It had been sitting in a hay field for at least 2 years if not 3.
I bought it because it had a shell in good shape and all the glass/doors were still there.
I knew I'd be doing a remodel on the trailer because the insides were trashed and the floor plan really wasn't going to work for us.
When the previous owner decided to park it, he left everything that he didn't care about behind.
In the front
Looking toward the rear
There was food in the fridge, I ratchet strapped it shut and disposed of the entire thing since it wasn't even a 12v/propane unit. And I wanted NOTHING to do with its contents.
There were mouse nests in other appliances..
The oven, later when I took the stove top out, there was another one under the catch tray.
In the pantry shelves
I hooked up, the lights *mostly* worked, so I towed it 80 miles home without any problems.
The sagging butt on the 05 is not because of the trailer, its because the previous owner put too much of a 'level' kit in the front end, and I haven't changed it.
Once home, the first thing I did was clean it.
Anything soft like blankets or clothing was burned.. there was so much disgusting mouse droppings, I was wearing rubber gloves and a facemask for this portion.
Plastic went in the trash, metal went in the recycle bin at work.
Some things like the pull out couch got burned first, and then the metal frame went into the recycle bin at work.
I kept the propane tanks, those aluminum ones are spendy and they appear to be stock for this trailer. I will get them recertified before using them.
Its started looking a lot better in there.
This split twin bed setup was never going to work for us, those things are about 2.5ft wide and 6ft long and there's no way to join them. And I burned the mattresses...
I had to find the right torx bit to take down the 'entertainment center'
More stuff headed to the trash
By this time, the trailer is almost completely void of anything that mice may have found of interest, all of the original walls and appliances are still in it.
In the front
