20 Circuit Painless Style Wiring Harness
68stang289
My dad bought this for my 70 Mach originally intending to use this instead of the factory harness. As they usually do, plans for the build changed and I had Mid work his magic on the spaghetti that was my underdash and underhood harness, so I no longer need this. It is made by a company called It's A Snap here in the USA. They label the wires every 4 inches down the harness as well. We did partially install the harness and make some connections, but the harness has never had any actual power through it. All of the wires and everything that was included as new should be there.
Features include (from the manufacturer's website):
*We developed the ultra compact fuse panel-base which is only 1.5 x 3.5 Inches and is Pre-Wired and ready to run!
*Unlike other manufacturers, we use only GXL heat, flame and oil resistant wire.
*Our head and taillight wiring is 25 Ft. Long. Others are shorter to cut cost
*We use Large 8 Gauge wire for the main power feed to run heavy load accessories. Most others use only Smaller 10 gauge wire.
*Every harness is Manufactured in the U.S.A.
*Our wire is color coded, labeled and numbered every 4 inches, making It a Snap to read and Install
*21 Circuits
*20 Fuses
*1 Relay
*2 Flashers
*Easy to hide in the glove box or console or mount to the steering column
*Proven Reliability! Over 20,000 Model ZZ-20 harnesses sold in the USA alone!
_______________________________
Looking to get $125 or so for the setup.
