Ponyman66
Yak, yak, yak
I love my truck and it's been pretty darn reliable. It's a 2001 F150 that I got used in '05, but only had 23k on it. During the last month or so it would stumble and hesitate a little when cruising. There were no codes captured...ugghhh. I had planned on just cleaning and lubing the Idle Air Comp Valve (something I had to do at around 75k). Last week while running errands it just started running like crap and the "service engine" light came on. When I got home I pulled the codes and it had a misfire on #6 cyl...finally a code! I've had to replace on coil pack on it before, but it tripped the "check engine" light that time. Hmmm. :confu
Since the truck now has 102k I figured I'd just replace the plugs, all the coil packs (since I figured they'd start failing over the next year or so...and they have to come off for plugs anyhow!). What a royal PITA! The #4 and #7 cylinders are the worst! I thought #8 would be a bear, but it wasn't too bad. The #7 cyl is a bear because the regulator is almost over the top of it. It took just over 2 hours to replace everything and clean the IACV. When I fired it up it had a slight rough idle, but it quickly smoothed out. A quick road test and it was running smooth as silk. I sure am glad to be done with that. Hopefully I'll have a new truck long before I have to go through that again!
p.s. My buddy has a '97 with a 4.6 that he's been asking about a time to do a "plug changing party". I can now say I will supervise, but HE'LL definitely be doin' the wrenching...and cursing! LOL
