janschutz
Corn Hauler
My wife's 59 F100 has dim headlights. Someone before me replaced the electrical harness with one from American Auto Wire.
I replace the headlight switch 3 years ago (the old one did not work). I moved the wires one at a time (Does not mean that it was wired correctly).
When the low beams are on, there is 8.97 volts from the hot wire to the ground wire. At High beam, there is only 5.5 volts from hot to ground. When the High beam is on there is .34v on the low beam hot and on low beam, there is .18 volts on the high beam hot.
Tomorrow I hope to be able to pull out the light switch and check it. I also plan to run another ground wire for each headlight. Also I need to find a pin-out for the headlight switch.
Any more suggestions?
