RyanG85
After reading Steve's post on rear 3-point belts, I realized I have yet to set up my front 3-points. Any good "how to" links out there? I'd like to have retractables....
"Jonk67" said:Steve, did you buy from GotBelts? I am holding off on measuring until I can make sure I have the length you mentioned right. Too short and it pulls, too long and it doesn't retract enough and ends up hanging in the door sill and getting slammed in the door when you get out.
What is the proper way to measure this length? from the bottom retractor mount to the roof attachment and down to where the receiving buckle will land on my right hip?
Just as you I plan to add the 8" sash, did you get the chrome buckles that look like plane buckles ('60's look)? Pics would be great, especially buckled/unbuckled showing the pillar.
"crustycurmudgeon" said:Just a FYI - I recently fixed the links to the pictures in my write-up. They had disappeared.
Frank
"Jonk67" said:Lets say those 3 lenths add up to 100in. when I'm sitting in the car, what length belt should I order so that it will fit comfortable and retract all the way to the door post when I get out or is that how they work? Something makes me think they won't retract to the door post due to length or having to constantly adjust the male spade end down to end up at your hip where the buckle is. I thought about the fact that the buckle needs to be at my right hip now making it short so that the triangle goes as far across as possible. I was just going to adjust the buckle (hump side) short and have a sewing place cutoff the excessive extra belt and sew a folded end on it again leaving a few inches for adjustment but not the 1ft.+ loose belt I'm expecting there to be.
"Jonk67" said:So when you let it retract against the door (slack) there is 140" left out of the retractor right?
"AtlantaSteve" said:Brian, when you reassemble everything, are you keeping the third point there, or are you considering moving to the roof?
"Havok1" said:Your absolutely right Steve. I was completely happy with the belts while the car was running. They were very comfortable. They didn't seem like they got in the way of someone getting in the back seat due to the low point as well. I will most likely keep them the way they were. BTW, your belts look good there Superman.
