Indycanard
Always something...
After 12 months of interior restoration on my 65 Conv, it is getting close to being done. Summer in Seattle is near, and driving on the first sunny spring day is my goal..
So here is my latest issue.
I am "upgrading" my interior from standard to deluxe. I have replaced the door handle and mechanism from the standard to deluxe configuration. The longer stem is to allow proper clearance with the thicker interior door panel.
I installed my passenger door panel, but the stem still doesn't seem long enough. I actually needed to push the pistol grip door handle a bit to get the retaining screw to start, with the screw about half way installed, these is a significant compression of the door panel. The handle does not easily operate, and doesn't return to the normal position after the door opens.
Obviously something is wrong. I do have the escutcheon and plastic "washer" installed.
Anyone have any ideas? I am thinking the "deluxe" stems are too short, although they are longer than the ones I removed.
Thanks
Thanks
