stump
After a drive last weekend I noticed the left tail/brake light on the Fastback wasn't working. This car has all new wiring, and the tail light plug is solid wiring (not the removable pig tail like my coupe). While checking for a loose connection I determined the problem was inside the plug. As I had the original pigtails from the coupe I decided to cut off the plug, add connectors, and use it. It's worked perfect all week. Meanwhile, I ordered a new set, which I used to replace the one from the coupe.
Well yesterday I replaced the pigtail and below are the results. As you know, with only two color coded wires, it's really hard to get the connections wrong... Also, I've only replaced the left side.
1. While applying the brake the instrument lights come on.
2. When the lights are on both brake lights are illuminated.
3. Brake lights work unless lights are on.
4. With the left pigtail disconnected the right works fine.
I replaced the new pigtail with the old one again, and everything's fine. No doubt something is going on inside the new pigtail; any suggestions on what it is, or how I can troubleshoot?
Thanks,
Gary
Thanks,
Gary
