68stang289
Looking to clear out some parts from the garage that I have been moving around for far too long now. All prices are OBO + the ride (or local pick-up in Southwest Florida), or trade for a set of 1" lowering springs and/or a driver/decent quality 70+ rimblow steering wheel. Pictures are available upon request.
69 Interior Quarter Trim Caps (pair) - $5
Fills the gap between the rear interior quarter panel and the sail panel in the corner where the pinch on windlace ends. Average condition original part.
FE Accel Distributor - Offer?
Came off of my 428 when I went with a new setup and has a new gear on it. Bearings and gear are new. Includes cap and rotor. Has some black paint up the side and could use a good cleaning. Dual points with no vacuum advance and a tach drive setup.
60-63 352 FE Distributor - $5
Single points distributor with vacuum advance. Could use a rebuild. No cap or rotor. Was told it was 390/428 when I picked it up, but the C0AF12127D (1FB) number says otherwise.
NOS C90B12250A Wiring Harness - Offer?
New with Ford tag still attached. Master Parts Catalog says it is the pink resistor wire used for the coil.
67/68 289/302 Pressure Side Power Steering Hose - $25
Brand new, never used. Pressure side hose from the pump to the control valve. I ended up using the P/S setup on my 70 and this hose will not work for what I need.
67-70 Pitman Arm - $15
Has been media blasted and primered. For manual steering cars. I believe it is a 1 1/8" diameter sector shaft fitment. Great shape, but I swapped over to PS.
69/70 302/351? Power Steering Bracket - $5
I believe this is correct for a 69/70 302/351 (I couldn't find any part numbers on it though). It's in good shape but it could use a decent cleaning and some paint.
Small Block (302/351)? Power Steering Pulley - $5
Not entirely sure what this is correct for as I could not find a part number anywhere on it. It measures approximately 6 1/4" across and has a sheeve width of approximately 5/8" from inside lip to inside lip. I was told it came off of a small block 69 Cougar when I picked this part up. Please someone chime in if this is incorrect as I do not want to misadvertise it.
70+ Rimblow Steering wheel and pad - $125
Needs restoration. Pad was repainted black from green at some point and the paint is starting to flake off in places. Missing the 3 inserts, but has the center running pony insert. Wheel itself has the usual cracks. I was going to have it restored, but I decided to put the money elsewhere and just look for a decent driver quality wheel instead.
