It's been way too long but how do you normally feed the wiring to the passenger's side rear lower interior panel light? If I remember correctly with Shag, I tapped into the harness on the driver's side and ran a power wire under the lower back seat over to the passenger's side, up under the panel to the light. Is this correct or did Ford run this wire down the passenger's rocker molding to the light?
