68 lower control arm
Here is what it looks like.
<img src="http://www.stangfix.com/testforum/gallery/10/468-210612132338-10145101.jpeg" />
<img src="http://www.stangfix.com/testforum/gallery/10/468-210612132327-100331811.jpeg" />
I have one that looks a lot like that one. It doesn't have the same jacking tabs but the shape, sway bar mount and type of ball joint is the same. The issue is, the one I have here has the 1 9/16" OD bushing that Ford put in some of the lower arms. Most of them had the 1 7/16" bushing and Moog used that size for the aftermarket lower arms they make. Our LCA bearing kit has a 1 7/16" OD. It looks like your arm has the larger bushing too so you need to check it out before you get started on it. Most of the Ford arms and all of the Moog aftermarket arms will work but those with the larger bushing won't. I'll look around some more and see what I can come up with. If someone has a set of old worn out Moog arms, those would work great.
John, You are good, This one has an 1 9/16" OD bushing. I guess I will be looking for some other cores.
