'68 radio rear bracket
mert
Getting closer on the S GT coupe. Dash wiring/AC underway. Bought the car in pieces and the bracket for the rear of the radio is missing.
Looks like a bendy-bit, anyone got a photo of one and some approximate sizes, as it looks like it would be pretty easy to fabricate something quite close...assuming I knew the dimensions....
For a non console radio install, it should be a slam dunk in fabbing a piece of metal to connect the back of the radio to the mounting screw under the dash.
The PO of my car had used a strip of plumbers tape (I think that is what it is called - the flexible metal strip with holes punched down the middle) to secure the back of the radio.
Thanks for the replies. Ended up pulling the Shelby console out of my convertible to get access and taking the one from there as a template. Took longer to remove and repalce the console than to fab up the DIY repro....
