68angrypony
Ok so I am going a bit crazy with trying to figure this out. I have a 68 mustang that I'm putting a 351c into. I'm going to switch from a t-10 to a T5. So I picked up a trans and bell from a 2000 v6 mustang. I know it may not be the strongest and could blow up and I'm ok with that as I can always rebuild it or replace with a built unit down the road. I got the set up for 80 bucks so I can't really go wrong. Not being able to figure out what flywheel and clutch set up and what I would need to do to use a mechanical clutch, I went out yesterday and picked up a fox body bell housing for a 5.0. I heard it would be easier to work with as it is more common and their is more knowledge online. So I have a buddy who will put in the shorter input shaft so I know that won't be a big issue. I still need to figure out which flywheel (I know i need a 28oz), and clutch set up to use as well as what I need to do to the fork in order to use a mechanical clutch. I also know my 68 mechanical linkage won't work so I know I need a 69 or newer set up. Does anyone have experience/knowledge in all of this and can help me sort this mess out?
Thank you,
Thank you,
