69 351w Engine Ground
Dyno68FB
Does anyone know where to ground a 69 Windsor. I am looking for a bolt to ground to on the block. Thanks.
The block's main grounding point is down low on the passenger side, close to the alternator. That's where the alternator and battery ground the block. There's another ground strap from the passenger side rear head to the firewall.
I'm using a one wire alternator. There is a pre-tapped hole in the head right behind the alternator that I used. Thanks for everyone's help.
I have a thick cable that goes from (-) pole of the batt to the chassis and one thick cable from the chassis to the engine/trans.
Used some of those below to make sure ground contact is sufficient.
