Sluggo
Dynacorn[nb]While finishing up the Boss and getting ready to paint it, I noticed that the lower rear edge of the deck lid was too long. It hung at least a 1/4 inch lower than it should have. This would not be too big of an issue on anything other than a Boss. Because of the way the blackout is carried onto the 1/4 extensions, this extra length would be very evident.
The second concern with the part is that center of the rear edge was drawn up tighter so when you looked at it from far off you could see a upward bow in it. Again, not a huge deal except when you factor in the huge contrast between Calypso Coral and SG Black.
The third concern was the upper rear edge, did not match the curvature of the quarter extensions. To me, this a critical line. I was not about to shave the 1/4 extensions to match the rounded over edge, and I was not going to mud the whole top edge to make it match the extensions. Overall, it was a pretty crappy part. Not what I'd expect from Dynacorn. I've used their doors before and been hapy with the fit. [/nb] slug score 3/10 (actually kinda generous)
Classic Reproductions[nb]Got this part as a replacement for the Dynacorn. The only issue with it was that it has a slight bow where the deck meets the rear window filler. Easy fix. All other contours matched as one would expect a new part to. Part fits and requires no filler to make it work.[/nb] slug score 10/10
