DougG69
Does anyone know if there should be some sort of gasket/sealer between the 2 halves of the heater box in a 69?
I have pulled mine apart & cleaned, painted, glued in new foam etc., and it seems like there should probably a gasket of some type, but there wasn't one in the rebuild kit and all the foam seals were pretty much dust. I am thinking of maybe using a little 3M strip caulk. Or?
Other than that, all I need to do is test the new heater core for leaks & put it all back together
ep
