70 alignment specs
RapidRabbit
Well I finally got my roller perches in. Now I need to get the alignment done.
The car goes to the shop Monday and they are going to do the alignment on Tuesday.
What are recommended specs for the following setup?
70 Mustang
Stock control arms
Shelby/arning drop
Granada spindles and disc brakes
Roller perches
Grab a trac 620 1" drop springs with 1 coil cut off.
Thanks
0-1/2 degree negative camber. Preferably a bit negative.
2.5-3.0 positive camber....I'd try to set it 2.7 on the left and 3.0 on the right.
1/8 inch positive total toe.
Never allow your cross-camber or cross-caster to be more then .5 degree different.
You should really try to get the camber perfectly even side to side.
The right side caster a bit more positive will help counteract road crown.
The positive toe will make the car track better.
The positive caster will aid in straight line drivability and steering wheel return.
Thanks Sluggo!
I have never been good at alignment stuff. Couple more days and I get to get her on the road again. :ecit :ecit
