southern_boy
So we got the new distributor dropped in and wired up, then, we tried it, and nothing. We ran a hot wire, and it started right up for a split second, and as quick as it started, it died, and nothing else happened. Why???
"B67FSTB" said:I assume you know how to check your complete ignition system.
Crank at TDC and rotor in dizzy pointing at 1 cylinder.
I believe the rotor goes counterclockwise and you know the firingorder ??
Make sure that is right.
Porre some fuel in the carburator and start the engine.If it fires right up , you have a fuel problem.
Otherwise you have an ignition problem.
My 0.02ct opinion.
"B67FSTB" said:After reading your thread again , it occurs to me that you have no connection between the plus (+) from the coil and the ignition switch.
During cranking the engine , the ignition gets it current from the starter solenoid.
When you stop cranking the engine ( the engine fires up) the ignition gets it current from the ignition/starter switch.
Look for that feed.Try to post a wiring diagram from its ignition system.
"southern_boy" said:So we got the new distributor dropped in and wired up, then, we tried it, and nothing. We ran a hot wire, and it started right up for a split second, and as quick as it started, it died, and nothing else happened. Why???
"Mach1Rider" said:Instead of chasing your tail, go back to the basic set up.
Start by dropping in the stock pointed dist and do a TDC timing set for points and timing.
This will at least let you see if will run or you have other issues causing the start problem.
"B67FSTB" said:First , at all times you have to have at least 10 volts at the + pole of the coil.Take a voltagemeter to check.
When you have this , pull a boot from a spark plug and put in another spark plug and lay it down so it is grounded to the engine.
When you now crank the engine , you should see if you have ignition.When so , you have a fuel failure.
How did you established that hot wire ?? Did you run a wire from the + pole of the battery?
Take a startercabel and connect the - pole of the battery with the engine itself.
I have a thick wire from the - pole of the battery to the framerail. And from the frame rail to the engine/trans.
Modern cars are setup like this .Ground straps are very important !!
"B67FSTB" said:Are you sure you don't have ignition? and not a fuel problem ?
Unhook the condensor at your dizzy.
Pics please .
BTW Determinate TDC , you can be 360 degree out of timing.
TDC = Piston 1st cylinder at highest point AND both valves closest !!!
"AzPete" said:Just r&r it....easy.
"Horseplay" said:remove and replace
