"robrod1" said:... cut my fox driveshaft to legnth and be done with it right. i am gonna use the t-5 and motor out of the car as well.
I was under the impression that some shops wouldn't/couldn't lengthen a driveshaft? On second thought, you can get a completely new, custom steel d/s for ~$180, and I'd assume that you'd have to re-tube a driveshaft in order to lengthen it, and that usually runs $100+, so buying a completely new unit might be cheaper/smarter."stangg" said:Actually you will need to lengthen the driveshaft. I pushed the motor and T5 back about 4" and used the Fox driveshaft, so I'm pretty sure if you use the stock motor position then you'll need to lengthen the driveshaft at least a few inches.
I'm running a 9.5" wheel in my 67 with leaf springs. My tire cross section is 10" or so and they fit with out a mini tub. I think you would need to check the tire width at it's widest point, maybe just rolling the lip would work but it will be close!"Starfury" said:I don't believe 10" wide wheels will fit under the fenders at all unless you switch away from leaf springs.
