drummingrocks
I've got an '87 GT that I restored as a daily driver, and it's developed an annoying electrical problem that I can't seem to figure out.
When I turn on the parking lights or headlights, the gauges in the instrument cluster immediately begin reading higher--almost as if turning on the lights is somehow sending more voltage through the gauges: the tach, oil pressure, voltage, and temperature gauges steadily rise until they're almost reading off of the gauge face (i.e., what we always called "pegging the needles").
To me, this sounds like something in the lighting circuit is searching for a ground. Keep in mind, this problem ONLY occurs when the lights are turned on, and it happens whether the parking lights and/or headlights are on. Sometimes when driving, I can hit a bump, and the gauges will return to their normal positions for a few minutes. A few minutes later, the next bump will make the gauges start reading high again.
So far, I've:
--Checked and cleaned all the visible grounds on the headlight harness itself
--Verified that all of the ground wires that run inside the car and under the dash are grounded, and that nothing is left loose
--Verified that the ground strap from the engine to the firewall is intact and installed correctly
--Sanded both the ground terminals AND the areas they attach to in the engine bay to ensure a good ground
--Replaced the rheostat switch in the dash
--Pierced the ground wires in the instrument cluster wiring harness and physically grounded the wires with test leads, with no change
Can anybody offer any suggestions as to what to do next? I still feel like the headlight circuit has a poor ground somewhere, and that's causing the circuit to occasionally search for a ground, ultimately making the voltage reroute through the gauges.
Thanks for any help! I've been chasing this particular problem for quite a while now, and to be honest, I'm tired of putting up with it!
So far, I've:
