What are the chances the perches for the springs will be the same width as my 65 springs?
"daveSanborn" said:Is the 8.8 rearend that you're looking at have the center section/pumpkin "centered".... or is it offset to one side? This could be your biggest problem.
"Tungsten" said:On the 9" rears, they are out of a F-150+? What are the chances the perches for the springs will be the same width as my 65 springs?
"daveSanborn" said:Slim to none.
As far as the 8.8 rearend being wider.... this is not as much of a problem if you use late model style wheels with more backspace.
With a "stock" size rearend, you'll need to add 1" spacers in order to run late model wheels. With the wider 8.8 rearend the spacers wouldn't necessarily be required when using late model (larger backspace) wheels.
"stangg" said:I've got an 89 LX rear end in my '68. The pinion yoke is pretty close to center so that won't give you any issues. I'm running Bullitt wheels with 5.72" back spacing and also used 94-04 axles that widen it by 1.5". So if you stick with drum brakes and bullit wheels you shouldn't have any problems. If you need to replace your quarters and wheel houses, then you could use the 67/8 outer wheelhouses to pick up some clearance on the quarters if need be.
Don't forget, The stock 88 rear is only 4 lug so if it was converted to 5 lug, be sure you know what axles where used. The 5 lug disk brake axles widen it by 1.5" where as the ranger axles keep the same 88 width.
In regards to cutting off the 4 link brackets and quad shock mounts, that won't even take you an hour. I planned for a whole morning and had it done in about 45 minutes. The brackets are not welded all around so that simplified the removal somewhat.
