One_fast67
I was shopping for a 9" differential and found one from a '78 F150 in a local salvage yard. It has 3.50 gears and 31 splines. Only problem is it comes as a complete rear axle, not just the differential. Since it would be a package deal, would it be possible to modify the housing to go in my '67? The housing would need to be shortened, and I would need to have different housing ends put in to accept my rear brake caliper brackets. Changing the housing ends would mean different axles. Since the housing tubes are larger, different u bolts and shock mount plates would be required. Does this sound like something that could be done or would it make more sense to sell off housing and axles and put that money towards a housing and axle package?
