guruatbol
Always on vacation!
Ok, I sold my 7.3 powerstroke and got an old work truck. I don't need a commuter vehicle or traveling vehicle and still need a truck from time to time.
This truck is a 92 F350 4x4 with a 460 CID, Auto trans. the thing drives good but after a drive down to Hurricane today with the family to kind of shake it out a bit.
I found the usual rattles and loose interior parts which are easy enough to address. I do need to find some new front door glass for it a the glass in it is scratched.
Anyway, the questions are;
It seems to be very gutless! Going up hill empty it slows considerably. WTH is going to happen when I have a trailer behind it.
I read on the 460 forum that a 180 degree thermostat will help, but I am wondering if maybe the final drive ratio may be to high. It has 35" tires on it and is bone stock except for a 3" lift. It seems that even with the overdrive off and going up the hill that I take in the 65 at 80+ and in the Durrango at 80 and every other car I have at 80, this beast slows and the pedal is on the floor. Speed limit is 75. This thing doesn't seem to wind up very well. I do have to remind myself that it is a big block and not my little 289.
Should I change the exhaust? What about a chip? Maybe the air filter is too restrictive?
The other major issue I have with it is the AC at low vacuum blows through the defroster and the fan is missing a speed. I know how to change the fan, but the vacuum issue is a puzzle to me. I wonder if there is a vacuum canister under the hood or the vacuum pot under the dash?
Any constructive advise on how to make this a better rig would be appreciated. An no I am not going to find a donor Cummins and swap the engine. I wouldn't be opposed but I have a project hot rod and don't need anything else, I need to finish the 65. Thus inexpensive solutions are best since every dollar spent on the truck is not going to go toward the 65.
Thanks,
Thanks,
