AzPete
So.....I have had a previous owner master screw up on this car since I purchased it and have decided it is time to fix it. The PO has been running a standard direction water pump with a smooth pulley using the ribbed side of the serpentine belt. This setup allowed him to run a short belt in the basic triangle with the crank, alt, and w/p. Local short trips and all day driving around town and all is well. Now, after 10,000 miles on it, I have found a little problem. Yesterday I drove at highway speeds of 55-60 for the 85 mile trip out of town, All was good. On the return trip, all was good until we picked up to 65-70 as a steady speed. First time at those extended speeds. My temp had a steady increase with no loss of fluids on ill effects. Ran around 215-220 real steady. All was good after returning to town and allowing the car to cool good. BTW, damn nice drive all day.
What I figured was happening, was the belt was slipping a bit on the w/p pulley being it was smooth on the ribbed side of the belt. This slowed the water flow even though I had cooling air flow, the water could not circulate to cool the engine properly. The car has a flex fan.
Now, since I will not get A/C for a while, I need to install an eliminator bracket and get the reverse flow w/p and a new fan and belt. This will solve this odd warming problem at high speeds and get me one step closer to the a/c setup. Such fun....
Does anyone have a picture of said bracket on a 302 from the early '80s with just alt, crank, and w/p? It looks to be a flat bracket and it relocates the tensioner pulley to be the combo tensioner and idler in place of the a/c. Looks easy to duplicate if I had a pattern from someones that is not installed. http://cgi.ebay.com/ebaymotors/Trick-Flow-51500600-A-C-Eliminator-BracketFord-Mustang_W0QQcmdZViewItemQQhashZitem5ad8177d51QQitemZ390172474705QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_3204wt_897
Long way to get to the end..............
