pnandy
k so im having engine rebuilt and in the process im going to add a/c ill be running a fox body serpentine style setup with march pulleys
i want to know if its ok to have the a/c compressor bolted on and spinning but not hooked up while i run the the engine for awhile it will probably be a couple hundred miles till i have time to connect the hoses install the a/c kit and charhe the system
