I'll be installing a Canton T-pan soon along with a new oil pump & driveshaft. I'd like to also install a windage tray but this would mean replacing 4 main bolts with 4 studs to attach the tray. Will this create an issue with the torquing sequence of the crank? The original engine runs fine now (112k) and I won't be rebuilding it for 1-2 more years so I don't want to create an issue with bearing failure if I unload the torque on only 4 bolts. Is it best to wait until the rebuild?
Thanks for any info.
