AFR from Dyno....Opinions?
65fast
This is my AFR for my 302 running a edelbrock 600 carb on about 9.0:1. Haven't noticed any knocking in the higher RPM's and plugs are good.
Should I richen it up some up top? I would love to get rid the fuel dump around 3k too.
You might be able to go richer and dial in more timing if you'd like.
But if your car is naturally aspirated and not pinging, I wouldn't worry too much about the upper rpm AFR.
Not an expert here but is your 3000 rpm fuel dump possibly a power valve problem or incorrect spec?
