JRANGER
Ok so ive been reading and reading and trying to figure out how my alt is going to be hooked up. The wires are all jacked up and spliced together. So Ive got a new Concours Headlight harness and will be ordering a new alt wiring harness to go with it.
So i looked at my alternator and I see only 2 wires hooked up.
A thicker black wire to the top post and a smaller white wire to the lower post. Thats it.......I see no ground what so ever. The thicker black wire (maybe 12 gauge) goes to the solenoid via a split in the wire. This all seems to look similar to the small block setup. My question is where does the small ground go on the harness? Does it go to one of the other 2 post on the alt or do i ground it out where ever?
This is the harness i was going to get.
I assume the red wire will be used as the white and the bigger connection as the top connection. The bigger split connection i assume goes to the solenoid and the small the ground?
Does that seem right?
![WALT4A.jpg](http://www.cjponyparts.com/images/450/WALT4A.jpg)
