tarafied1
My 93 LX is draining the battery overnight. I can jump start it and it will start. If I trickle the battery it will start within a few hours but overnight it's dead. I put my volt meter on the battery after charging it and I can watch the volts slowly drop, very slowly. If I disconnect the Alt, the voltage drop stops. I had another voltage regulator so I swapped it to see what would happen. Didn't fix it. Do you think I have some bad diode's?
